[Today at 08:44:26 PM] JonB: Just paint them off, threads and all?
[Today at 08:45:31 PM] SchizophrenicMC: Yeah, if you spray like you would a model kit, in several thin coats, you should be fine
[Today at 08:46:31 PM] JonB: Ok
[Today at 08:46:55 PM] JonB: Three of four body mounts done
[Today at 08:47:37 PM] JonB: Takes about two hours to make each. Hope to be ready for the extended week end
[Today at 08:48:22 PM] JonB: Don't even know that I'll get that far, but the mounts are something I can do here in my basement
[Today at 08:49:34 PM] JonB: Pulling, seem welding, and painting the subframe is unlikely, considering I have to set up an axle, which I'm hoping to strip and paint also
[Today at 08:50:07 PM] JonB: Never know though - of I feel good, with a three day build binge
[Today at 08:52:53 PM] JonB: There's mount for the rad support also. I'm not doing those as I'm going to rebuild that out of something light weight
[Today at 08:54:33 PM] JonB: I found my self shopping for aluminum bolts for the fiberglass fenders, then I realized I was pretty insane
[Today at 08:55:50 PM] JonB: Being that I'm chucking the inner wheel wells, there's only going to be about eight bolts for each fender
[Today at 08:56:26 PM] JonB: I'm going to loose the hood springs and mill many holes in the hood hinges
[Today at 08:56:42 PM] SchizophrenicMC: lolweightreduction
[Today at 08:56:52 PM] JonB: Massive
[Today at 08:58:28 PM] JonB: I was considering stripping the steel inner fenders out of the old fenders and welding them to the rad support, much like a modern unibody, but I think I'll just wait for cage
Author
Topic: Kustas Project: CA18DET #2 (Read 28449 times)
