[Today at 12:13:45 AM] Wonderingraven: and the love for kouki's
[Today at 12:14:25 AM] SchizophrenicMC: That's a zenki
[Today at 12:15:42 AM] Wonderingraven: I mean zenki
[Today at 12:16:00 AM] Wonderingraven: I forgot I don't deal with s14's lol
[Today at 12:20:00 AM] SchizophrenicMC: My friend wants a kouki
[Today at 12:20:21 AM] SchizophrenicMC: Even though they're like 4 times more expensive
[Today at 02:27:37 AM] SchizophrenicMC: http://i.imgur.com/f1TZZUq.png
[Today at 03:40:34 AM] SchizophrenicMC: http://imgur.com/a/3rrF6 I hate people
[Today at 02:08:45 PM] silverton: wtf?  so low he sheared his trans pan right off?  or is that his oil pan?
[Today at 02:12:23 PM] SchizophrenicMC: That's his front subframe
[Today at 02:12:42 PM] SchizophrenicMC: He's so low, he scrapes on flat ground
[Today at 02:26:57 PM] SchizophrenicMC: http://dallas.craigslist.org/dal/zip/3824437434.html wat
[Today at 02:33:10 PM] silverton: flagged
[Today at 03:21:44 PM] SchizophrenicMC: I thought of that so I mirrored http://i.imgur.com/5oUe2nd.png
[Today at 03:47:36 PM] Wonderingraven: lol
Author Topic: idle rpm's  (Read 262 times)
Offline night_s12
  • hmmm......
  • asking too many questions
idle rpm's
« on: 03:40:39 AM / 30-Mar-12 »
So it idles at about 1k. Im just wondering if just turning the dizzy would be the best way to get it back to 700 to 750 where it should be.  Cause i dont have a timing gun so i cant just redo the timing
"speed limits are like herpes, you can never get rid of them"-Jeremy Clarkson
Going places knowing your driving something you won't see every five minutes is priceless
1988 200sx SE-ROXY
1987 200sx xe hatch back - Shelli(sold)
2002 mitsubishi lancer OZ rally- daily driver - Flow(traded for SE)
Offline Fhu
  • Vehicle: 1988 Nissan Silvia S12
    • S12 project Fhu
Re: idle rpm's
« Reply #1 on: 06:03:10 AM / 30-Mar-12 »
You shouldn't touch the dizzy
Th best way is to turn the idle screw on IACV
Offline night_s12
  • hmmm......
Re: idle rpm's
« Reply #2 on: 02:39:05 PM / 30-Mar-12 »
Alright cool i just wanted to make sure before i fucked with it thanks
1988 200sx SE-ROXY
Offline mc
Re: idle rpm's
« Reply #3 on: 03:33:56 PM / 30-Mar-12 »
...get yourself a timing gun so you can play with advancing it properly/safely..the vg30 responds great to timing adjustments...craigslist is great for picking up used tools for cheap but its not really that expensive for a basic gun.
Offline d_k_jose_s12
    • http://myspace.com/d_k_jose
Re: idle rpm's
« Reply #4 on: 03:44:47 PM / 30-Mar-12 »
Harbor freight had great deals on timing guns if u want I can email you a few cupons
Offline night_s12
  • hmmm......
Re: idle rpm's
« Reply #5 on: 05:44:29 PM / 30-Mar-12 »
Coupons are always welcome lol ill have to wait for employment to get one tho. Idling a little high isnt gonna hurt the motor right? I jist wanna make sure
1988 200sx SE-ROXY
Offline 1NZS12
Re: idle rpm's
« Reply #6 on: 09:56:27 PM / 30-Mar-12 »
it wont hurt it at all, just use a bit more gas.
Offline night_s12
  • hmmm......
Re: idle rpm's
« Reply #7 on: 10:02:51 PM / 30-Mar-12 »
Alright cool
1988 200sx SE-ROXY
Offline gregorio
    • http://www.cardomain.com/id/boygregorio
Re: idle rpm's
« Reply #8 on: 01:02:36 AM / 02-May-12 »
The $13 timing light from harbor freight works like a charm, but you will probably need to pop off the upper rad fan shroud to see the timing marks on the crank pulley. No harm in loosening the dist. mounting bolt & rotating the dist. a small amount in either direction while the car is running to see if it smooths out your idle. (rotating it CW advances the timing). When smoother idle is obtained then adjust idle speed to about 850-900 with car idling in neutral. Then go back & adjust the timing to spec. using the light. You might have to repeat all the steps a few times & remember that the specs are plus or minus a very small amount so you can tune for what seems to work best or smoothest. You should also remove the dust cover from the crank angle sensor inside the dist. & carefully wipe off any dust bunnies & verify that the holes in the disc are all cleared out.
