[Today at 02:12:08 AM] SchizophrenicMC: I think tomorrow I'm gonna solder all the bad solder joints in my Jeep
[Today at 02:13:12 AM] StephenG: Buy a gun, its the single best thing you can possible do to keep your sanity
[Today at 02:13:37 AM] StephenG: soldering gun*
[Today at 02:13:41 AM] SchizophrenicMC: lol
[Today at 02:13:56 AM] SchizophrenicMC: The joints I'm soldering are all board joints
[Today at 02:14:19 AM] SchizophrenicMC: That is, this little 10A iron is sufficient
[Today at 02:14:29 AM] StephenG: oh, nvm then. Wont want to use it on anything with ICs
[Today at 02:14:38 AM] SchizophrenicMC: lol
[Today at 02:14:50 AM] SchizophrenicMC: There are maybe 4 ICs in this whole damn Jeep
[Today at 02:15:33 AM] SchizophrenicMC: But it's got a bunch of boards with various shit connected to them
[Today at 02:19:06 AM] SchizophrenicMC: I might install this vehicle information center in place of the graphical display module
[Today at 02:19:41 AM] SchizophrenicMC: If I do, I'll have to jury-rig this arduino into a device for mocking up sensor signals I don't have
[Today at 02:19:59 AM] SchizophrenicMC: Like the coolant level sensor and wiper fluid level sensor
[Today at 02:31:05 AM] StephenG: sounds like fun
[Today at 10:24:54 AM] Colonel Gustard: ca20 crossmember damn it!
Author Topic: Ka24de Into Mk1 Ca18et  (Read 2557 times)
Offline Deezus
  • Deezus Christ.
« on: 12:53:28 AM / 14-Mar-10 »
are there any writups on it, or is it the same as a KA24de to mk1 ca20e
« Last Edit: 01:06:00 AM / 14-Mar-10 by Deezus »
Deez why the flip are you so smart sometimes.
OMFG THE TROLL IS OUT!
Deezus is always in maximum trollverdrive mode.
« Reply #1 on: 03:17:28 AM / 14-Mar-10 »
i have the info, yes, but dont post it because i dont want people destroying what little remains of the turbo cars just because the ka swap is the thing to do with these... the ca18et can push some power in stock form...
if you need it tho, pm me with details of chassis year, ka year, etc, pics are good.
« Reply #2 on: 05:08:36 PM / 14-Mar-10 »
I think he bought an 85 18et with a ka already swapped into it and he has been having issues with it...if i remember right.
Offline SprockCapn
« Reply #3 on: 08:59:20 PM / 14-Mar-10 »
Quote from: 200sxkitcar
I would also be interested in this info if you don't mind. And I agree with trying to keep the ET in my car if I didn't have so many problems with the motor every time I drive it. I am on the other hand excited to have a (Hopefully) more reliable motor with a little more get up and go than my car has.
Offline DriftOner
« Reply #4 on: 01:21:24 PM / 15-Mar-10 »
Can I have this info too? I tried to pm you but it says your pm system is disabled or full. I have an 84 mkI ca18et and the engine is an s13 ka24de. Thanks
Offline Deezus
  • Deezus Christ.
« Reply #5 on: 05:02:18 PM / 15-Mar-10 »
Quote from: sam31183
yea thats whats goin on, and the wiring is rigged... a lot of stuff is hardwired to the battery and its causing all kinds of issues.. ive never swapped a motor before except a few v8s but it was 350 to 350. My friend is letting me borrow his hoist to pull my motor this weekend but i have to have everything done quick becuase hes putting a 454 in his craparo
« Reply #6 on: 02:18:40 AM / 16-Mar-10 »
pm box keeps filling up, i have alot of info in there.
ill pm you guys the info soon..
Offline SprockCapn
« Reply #7 on: 09:46:58 AM / 16-Mar-10 »
Thanks Sterling! I appreciate the help as I miss driving the Ol' S12!
Offline DriftOner
« Reply #8 on: 06:48:05 PM / 16-Mar-10 »
Thank you! I haven't driven my S12 in a few months since my head blew haha. I'm excited!
Offline Deezus
  • Deezus Christ.
« Reply #9 on: 07:28:05 PM / 16-Mar-10 »
Quote from: DriftOner
my motors fine... the wiring is just all fucked up.. it keeps burning ground wires and burning up ignition coils
« Reply #10 on: 02:36:30 AM / 17-Mar-10 »
S12 Connectors (located under the S12 MAF/Airbox combo)
There are some specifics you'll need to know:
1. The S13 BLACK/RED wire, its a thicker wire, needs to be connected to an S12 wire NOT in the connectors pictured. You'll need to pick this wire up at where one of the old S12 coils used to be, there is two possible connections (two coils) so which is up to you. This Black/White S12 wire will be large gauge like the S13 Black/RED wire. Since you had a Turbo model, you will have standard-type connections still on these Black/White wires, so either find a connector to mate to it (from a jyard car say) or strip&splice, its up to you. If you have any questions as to which connector or how this will work, just ask. In the other MK1 KA swap guides this is detailed, but CA20s use old style canister coils with simple eyelet type terminals which are easy to find and connect to. lmk if you have questions.
2. The S13 BROWN(sensors) and BLACK/YELLOW (air regulator) are going to both go to the S12 BLACK/RED wire, as there will be sufficent current available thru this wire (its a 10amp fuse) to power all the S13 devices that will be connected to it.
3. I made a change to the tach wiring. In the past, and in all the other swap guides out right now, I list a yellow/red wire as the tach output, which it is... on an s13. On an S13 tho its a much lower output for the computerized S13 dash, but S12s need the more solid 12v signal directly off of the coil. So what you need to do, according to the research I've done, would be to tap AT the S13 coil the Light Green/Black wire and connect that to the S12's LightGreen wire. I have not verified this, so I'm not 100% sure on this, and there really should be a diode/resistor in the line to prevent feedback, so if you want to leave it disconnected for now that would be allright. There is a diode/resistor IN the S12 harness already, so it might be possible to connect directly to this, but I need to look into this further. If you look near one of the coil locations, you'll see a little gray box wrapped into the loom, thats the diode, I think the s13 coil jumper for the tach should connect to it, but get it running first, and it can be figured out later.
4. The coolant temp sensor wire is also not confirmed, but it would be cool if you could test it out. The S13 BLUE/BLACK wire should be near the ECU connector where there are wires cut real short.
5. MK1 Turbos did not use neutral safety switches, I've not had any issue leaving them disconnected on KAs so there should be no problem there.
A good way to cap off the wires you won't be needing... seeing as yours are missing the connections. you might notice this connector is the engine harness side of the Turbo chassis connectors from above, I salvaged them from a burned harness, otherwise I prefer not to cut. Thats liquid electrical tape (Home Depot) dabbled in two layers over the bare ends,
In regards to the fuel pump, I will simply refer you to what I wrote for the MK1 CA20 swap guide, as that is the same. http://club-s12.org/v3/index.php?topic=21003 third post. Obviously the connector will be a bit different but use the pics above and you'll be fine, the function is the same.
here's the S13 harness connectors....
done.
« Last Edit: 02:38:44 AM / 17-Mar-10 by 200sxkitcar »
Offline Deezus
  • Deezus Christ.
« Reply #11 on: 10:32:49 AM / 17-Mar-10 »
thanks im still confused but after i read it like like 10000 times ishould understand.. i have a freidn whose swaped plenty of chevy motors and hes even put the motor in is saleen mustang, im using his hoist and hell be helping so if i gie him this hell probably know. thanks again
Offline DriftOner
« Reply #12 on: 11:42:03 AM / 17-Mar-10 »
Thank you!! I will be putting this to use this weekend. It won't be driving but it will hopefully be running. Someone came and stole the three parts I needed   They took the front half of my 240 driveshaft, my battery, and my radiator. They were kind enough to leave the rear half of the 240 driveshaft haha. What are the odds lol
« Reply #13 on: 03:32:49 AM / 20-Mar-10 »
just ask or pm me if you have more questions!
Offline d_k_jose_s12
    • http://myspace.com/d_k_jose
Re: Ka24de Into Mk1 Ca18et
« Reply #14 on: 07:17:08 PM / 09-May-12 »
so i got my self a laptop and a printer so i can print all the info to get my swap done i could not see it from my phone everything makes so much more sense now
