[Today at 08:21:14 PM] JonB: This is an IRS right? I've had both 180 and 200 it pry
[Today at 08:22:32 PM] JonB: There's a steel collar that rides on the oil seal that's pressed on the CV, try not to bend that. But sometimes they fight a little prying out
[Today at 08:24:02 PM] JonB: There's a groove in the CV and one in the diff broached section. Between them is a circular steel ring that keeps them in place - that's the resistance on the pry mostly. Sometimes the shaft just fits tight in general
[Today at 08:29:20 PM] SchizophrenicMC: Internal c-clip if I'm not mistaken
[Today at 08:34:09 PM] night_s12: driverside axel popped out easy enough. passenger one is being a bitch tho. cant get the crow bar to bite without slipping off. ill get it out tomorrow
[Today at 08:34:36 PM] night_s12: it is irs. its a r200
[Today at 08:34:45 PM] JonB: Good. So now you know that that's how its done, and what's in there
[Today at 08:36:13 PM] night_s12: yeah ill get it out tomorrow. yay for hot weather lol
[Today at 08:36:44 PM] night_s12: feels like im back in florida lol nothing like sweating ur ass off in the shade.
[Today at 08:50:08 PM] stocks12: http://www.carsforsale.com/used_cars_for_sale/1987_Nissan_200SX_178261538_3
[Today at 08:50:09 PM] stocks12: wow
[Today at 08:50:16 PM] stocks12: 14k.... they're out of their mind
[Today at 08:55:07 PM] stocks12: http://www.zcarblog.com/for-sale/1984-nissan-200sx
[Today at 08:55:11 PM] stocks12: this one is 9k
[Today at 09:02:39 PM] SchizophrenicMC: OP IS A FAG
Author Topic: Car won't start!  (Read 201 times)
Offline ShadowedXB
Car won't start!
« on: 06:38:39 PM / 19-Apr-12 »
Hey guys just a quick run down on what is going on. My stepdad and I pulled the motor out and rebuilt the bottom in and put everything back in today and had everything in other than the radiator and went to go start her and nothing would turn over but nothing so we started at our normal troubleshooting checked spark and was getting spark checked fuel at the feed line an return line and was getting fuel to the rails and plenty but still no crank. Spark plugs are none dry even though the rails have fuel so we are thinking that is electrical but checked all connections and they are all good. We are checking our timing now but was curious if anyone else has ran into this. Any input would help thanks
Offline Colonel Gustard
  • El Senor Gustard
Re: Car won't start!
« Reply #1 on: 07:38:48 PM / 19-Apr-12 »
If it isnt timed right it wont start. While cranking it turn the distributor all the way one way then all the way the other way and see if that helps. Also make sure your firing order is correct
"Certified Member of SoCal Parts Alliance."
what the hell is camber?
I thought about my s12 and the parts i want to put in her :P
Obviously, you have yet to meet Colonel Gustard.
I saw some of his posts, he seems like more fun than a barrel of hookers.
Offline ShadowedXB
« Reply #2 on: 10:54:50 PM / 19-Apr-12 »
The timing was off about 90° so that's why it would not crank.
Offline ShadowedXB
« Reply #3 on: 10:54:02 PM / 24-Apr-12 »
Dang it we finally got the car running well and we went to fix a exhaust leak under the intake and put everything back together and now it won't crank back up everything is plugged in and I am getting spark and fuel to the spark plugs but still will not run. I might have a intake manifold leak but I don't know if that is why it is not wanting to run or not. Well I guess one more day of working on but at least I got the timing right, finished the suspension and put new LSD fluid in.
