Wont Crank with Key
Started by Colonel Gustard, 10:16:17 PM / 09-May-12
Colonel Gustard
87 SE, since ive had the car, theres been a push button wired in for the starter. it was all ghetto installed wiring and wasnt spliced or anything into the OEM harness. I hooked up the original starter cable for the solenoid and tried to crank it with the key and all i heard was a click in the passenger side of the dash. I tried a new ignition switch and that didnt help. any suggestions?
"Certified Member of SoCal Parts Alliance."
Quote from: SlickS12 on 09:47:21 AM / 08-Mar-11
what the hell is camber?
Quote from: Prolowtone on 11:26:43 PM / 27-Oct-11
I thought about my s12 and the parts i want to put in her :P
Quote from: SchizophrenicMC on 03:11:12 PM / 02-Dec-11
Obviously, you have yet to meet Colonel Gustard.
Quote from: Ghetto Jack on 03:15:17 PM / 02-Dec-11
I saw some of his posts, he seems like more fun than a barrel of hookers.
Prolowtone
bad relay or something..... Gonna be a bitch to trace it down
Quote from: VG30DETT on 02:39:59 PM / 01-Oct-12
Quote from: StephenG on 08:06:21 PM / 28-Nov-12
I_heart_VVL
This same shit is happening to mine, though mine is stock.
I tried a new starter and still no work.
I think it's because I was charging the battery while cranking it the other day. Probably a blown fuse or bad relay.
Help!!!!
1987 SE V6 - Gone
2004 Mazda RX8 GT - Gone
2003 Subaru WRX - Gone
1997 Mazda Miata - SOLD!
2003 Nissan 350Z - Gone
1989 RHD RB25 S13 - Gone, thank god
1989 two tone SR coupe because s12s are dumb
Colonel Gustard
mine is stock too, i couldnt figure out why it wouldnt crank so i wired in another push button on my own from the battery to the button, then from the button to the solenoid, hasnt failed me once since i installed it
I_heart_VVL
Have you tried applying 12v directly to the starter?
1987 SE V6 - Gone
Colonel Gustard
Starter works fine, the problem is the start signal. I wired it so 12 volts goes to the connector where the start signal wire goes so it cranks
Wonderingraven
It's possibly a relay, change out the relays underneith the battery near the battery and I think in a few other places as well, or  Check the FSM it was one of the first things I checked when it wouldn't crank when i turned my key. and all I got was a click click.  Mine was just the battery pos cable, in which your case possibly not. Just have patients and check the fsm, you will find it.
Hacker | Streamer | Gamer | Drifter
1987 - Project: Excalibur Prime
1986 - Project: Serenity
Wonderingraven
Just an update to an old thread. My resolution was "the starter"  Even though the button maybe working, the solenoid if it's malfunctioning or something inside blown, it will just click.
I just spent 3 weeks on this issue, tracing the wires with a new ignition and all, it was a PITA. But end my day was with the starter and 300zx turbo starters bolt up with 0 issues, I rewired the whole wiring clip that came from the battery to the plug in on the starter.
So if you ever revisit this on your Hatch, try another starter especially one from an 300zx (I think they are all the same model / part number) I wonder if you might be with that same issue as well. Even though the start button does work.
Colonel Gustard
Yeah it doesnt bother me anymore lol, the push button is as reliable as can be, I grew fond of it
EternalSwap
Don't lie Gustavo- you love starting my car with a key :)
wow. im horny. i dont know why. but i just figured id let you guys know. i really wanna bite someones bean. i mean. chomp on some ass
Quote from: Arro on 12:26:40 AM / 10-Nov-10
hahah Alex just pwned C-S12, w3rd.
Wonderingraven
lol, makes life soo easy.
Colonel Gustard
I started an s12 with a key once, I hated it!
