[Today at 02:10:13 AM] SchizophrenicMC: lol
[Today at 02:12:08 AM] SchizophrenicMC: I think tomorrow I'm gonna solder all the bad solder joints in my Jeep
[Today at 02:13:12 AM] StephenG: Buy a gun, its the single best thing you can possible do to keep your sanity
[Today at 02:13:37 AM] StephenG: soldering gun*
[Today at 02:13:41 AM] SchizophrenicMC: lol
[Today at 02:13:56 AM] SchizophrenicMC: The joints I'm soldering are all board joints
[Today at 02:14:19 AM] SchizophrenicMC: That is, this little 10A iron is sufficient
[Today at 02:14:29 AM] StephenG: oh, nvm then. Wont want to use it on anything with ICs
[Today at 02:14:38 AM] SchizophrenicMC: lol
[Today at 02:14:50 AM] SchizophrenicMC: There are maybe 4 ICs in this whole damn Jeep
[Today at 02:15:33 AM] SchizophrenicMC: But it's got a bunch of boards with various shit connected to them
[Today at 02:19:06 AM] SchizophrenicMC: I might install this vehicle information center in place of the graphical display module
[Today at 02:19:41 AM] SchizophrenicMC: If I do, I'll have to jury-rig this arduino into a device for mocking up sensor signals I don't have
[Today at 02:19:59 AM] SchizophrenicMC: Like the coolant level sensor and wiper fluid level sensor
[Today at 02:31:05 AM] StephenG: sounds like fun
Author Topic: (MI) 86 parts needed ASAP!!!  (Read 329 times)
Offline Mikes200sx
« on: 08:55:41 AM / 10-Jul-12 »
I need I distributor, a passenger side window, the rubber peice that is below the passenger side window.
-1986 s12 w/ca20e. Mandrel bent 2 1/2  exhaust with borla muffler. Real ram air intake.
-1985 rx7 13b all stock
-1991 fzr1000...scary fast
-1986 4runner baja toy
Re: (MI) 86 parts needed ASAP!!!
« Reply #1 on: 09:38:21 AM / 10-Jul-12 »
86 ca20 has two options depending on the month it was made, Vacuum advanced or electronic?
Offline Mikes200sx
« Reply #2 on: 05:49:55 PM / 10-Jul-12 »
im pretty sure it is vaccum advanced because it has a little round thing on top of the distributor with one vaccum line going into it.my problem is the crank angle sensor within the distributor so i just thought buying a whole new distributor is easiest way to go.
« Reply #3 on: 09:30:32 PM / 10-Jul-12 »
Mike, if it's vac advanced I don't think it has a crank angle sensor. Rather, it should have an ignition module inside the distributer.  Others please verify this for me; thanks, Red
« Last Edit: 09:30:42 PM / 10-Jul-12 by rednucleus »
Offline Mikes200sx
« Reply #4 on: 11:48:58 PM / 10-Jul-12 »
ok when i took the distributor cap off it has a little block with 4 wires going into it...would this be the module or the crank angle sensor?
« Reply #5 on: 10:38:01 AM / 11-Jul-12 »
that's the module; can go to nissanpatszone.com to look at pics to verify - but I wouldn't buy one there!
Post Merge: 11:14:55 AM / 11-Jul-12
$50 on ebay
« Last Edit: 11:14:55 AM / 11-Jul-12 by rednucleus »
Offline Mikes200sx
« Reply #6 on: 03:18:54 PM / 11-Jul-12 »
can you send me a link to the 50$ one on ebay i cant find one used for under 75
Offline Mikes200sx
« Reply #8 on: 12:03:14 AM / 12-Jul-12 »
thanks and im just curious if ahbody knows if the ignition control module has anything to do with the fuel injectors. i have no injector power and was needing to know if this was the culprit before i buy.
THANKS
« Reply #9 on: 01:13:20 AM / 12-Jul-12 »
There's a diagnostic schematic in the electrical section (EL) under "Ignition System" of the FSM using a multimeter to test it - I would do that before buying one. The module does affect fuel injector function.
Offline Mikes200sx
« Reply #10 on: 08:01:22 AM / 12-Jul-12 »
ill look there but first what is the FSM?
« Reply #11 on: 01:05:17 PM / 12-Jul-12 »
FSM is the factory service manual!! I'll find you a link on Ebay - it's the book mechanics use
http://www.ebay.com/itm/1986-Nissan-200SX-Service-Manual-/370628703320?pt=Motors_Manuals_Literature&hash=item564b313458&vxp=mtr
Your trick is getting the right one for the '86. There's also a mid year revision one, but I think that has the other distributer. This is a MUST have for your car! My EBay search was 200sx service manual.  Get one!!
Here's one in better shape and cheaper!
http://www.ebay.com/itm/1986-Nissan-200sx-Repair-OEM-Service-Manual-/120852430427?pt=Motors_Manuals_Literature&hash=item1c235dbe5b&vxp=mtr
Post Merge: 01:21:45 PM / 12-Jul-12
http://club-s12.org/v3/index.php?topic=17058.0
There's also this link here on the club for fsm's on line
« Last Edit: 01:21:45 PM / 12-Jul-12 by rednucleus »
