Dilemna...
Started by alundra, 03:53:58 PM / 01-Aug-05
alundra
In order to increase my horsepower, must I:
-Fit my setup (intercooler+ colder spark gap reduced+ Manual Boost Controller -but not to screw it-) then go the garage (5KMs) to advance the timing, then back to home, screw the MBC for 0.7, 0.8 Bars viewed on my boost gauge
-Go to my garage full stock, advance the timing, back to home and fit my set up and increase the boost
-or something else?
The better way will be go at the garage stock, fit the setup (I/C, spark plug..), do the advance... but the garage want to fit the set up him self and as they said it will cost some 300€   :violin: ...
So?
shadowcat
Just fit the setup yourself. Go buy a timing gun for alot less than the install cost. You should be able to do it yourself from there.
alundra
I don\'t know how use it and i prefer not to kill my CA18ET  8-) .
So what is the correct option?
Keith
QuoteI don\'t know how use it and i prefer not to kill my CA18ET  8-) .
Loosen the 2 dist. bolts.....point and shoot timing gun to desired timing mark......re-tighten 2 dist. bolts.  Sweet and simple.
15 degrees + or - 2 degrees is stock.....which is the second tick mark from the right.  I have mine set to about 17 or 18 degrees.....which is closer to the last tick mark on the right side.....which is 20 degres
alundra
Thanks but already know the timing procedure ;).
But i don\'t have a flash lamp to adjust this it\'s not an simply operation you can blown you\'re motor.
Keith
I was just trying to save you some $$.  A good timing light in the U.S. cost around $50....maybe a tad cheaper.  The procedure is simple.....and if you adjust the timing with a timing light........you\'re pretty safe......just don\'t go past the 20 degree mark.......or you may get some detonation under boost.
