Gain Setting Tutorial
Started by Jmac279, 11:06:43 PM / 05-Jul-04
Jmac279
Here\'s something I hope you can will all use to your benefits.  As you may or may not have noticed, most equipment dies for one simple reason :  Most people push their equipment beyond its limits.  Whether its the amplifier or subwoofer or speakers, clipping is the number one cause of failure that I see.  To prevent clipping, I\'ve made this tutorial (Well, JL Audio did, but I\'ve been doing this for years before they put it on their site).
Okay, before I post the links, there\'s just one problem that I have with the following guide.  It says to use 75% of max volume.  I don\'t agree with this at all because, with some head units, you can crank it up to full without distortion and with others, it may only be 60% ...  To set your gains, use the MAX settings you\'d NORMALLY use ...  If the loudest you listen to your music at on a regular basis is 22/35 with bass @ +3 and treble @ 0 with MX on, by all means use those settings.  Also remember to have the car on ;)  It should also be noted that if you want to use bass boost, set it prior to the gains and use the center frequency of the bass boost (45 Hz for most amps) ...  Please remember that if you have a subwoofer volume control, set it to full before you set the gains on the sub amp ...
Here\'s the formula you\'ll need ...
Sqrt(Power*Resistance) = Voltage
(i.e.  If you bridge a 4 ohm subwoofer to your amplifier that is rated to produce 100 RMS @ 4 ohms in bridged mode, you would want Sqrt(4*100) = 20 volts)
Gain Setting tutorial ...
[url]http://www.jlaudio.com/tutorials/Input_Sensitivity/Input_Sensitivity.html[/a]
Test Tones ...
[url]http://www.teamtreo.com/view.php?showme=Free_Test_Tones[/a]
Hopefully, this will all result in greater longevity of your products and cleaner bass.  Some people still insist on cranking the gains after using this tutorial because it\'s \"not as loud as it was.\"  If you choose to do so, you may be putting your equipment at risk.  In the rare case that you find the bass is too much, feel free to turn the gain down.
Could a mod please sticky this ?
Alex Frost
It looks good...8)
I used to set mine to about 65%...before I took the subs out at least...I was always scared that I would blow out the back window. :twisted: 8)
The Nissan S12 Silvia...built while Nissan was still smokin' the green stuff
Cars...
2004 Nissan Sentra SE-R Spec V
1988 Toyota Supra Turbo->->NOT SO Turbo
1987 S12 hatch...KAZU is BACK!!! and she still runs!!!
1986 S12 hatch...GONE!
1980 Toyota Celica "Sunchaser" w/ 20R Sold
Team Frost; there's nothing faster than cats on grass!
project13
Quote from: Alex Frost
It looks good...8)
Thats funny, beacuse when I had my old 200sx hatch I did blow out the seals on my back window 2 times at stereo competions.  the first time was with my 4 10" fosgate power subs.  and the next time was with my PPI 12"s
Help me find my old Black 84 200sx turbo hatch back!
EternalSwap
I don't get it, whats this for?
wow. im horny. i dont know why. but i just figured id let you guys know. i really wanna bite someones bean. i mean. chomp on some ass
Quote from: Arro on 12:26:40 AM / 10-Nov-10
hahah Alex just pwned C-S12, w3rd.
Empedocles99
Quote from: EternalNewbie
Tuning amplifier and speaker stereo setups so you don't break either of the components through bad settings or component selection.
1985 Nissan 200sx Notchback (ca20e)
2005 Honda s2000 Sebring Silver (my daily driver)
1970 Chevy Malibu Astro Blue (a work in progress)
http://www.indolence.net/s12/
Sparco Sprint Seats, RCI 6 Point Harness, Tokico Illumina Shocks, SSC Springs, Front & Rear Addco Anti-Sway Bars, Porterfield R4 Metalic Pads, Konig Rewinds & Kumho Ecsta V710 205/50/15, Prothane Bushings, K-Mac Rear Camber Adjuster, z31parts.com Spring Seats, Autopower Roll Bar, Megasquirt & LC-1 Wideband (12.0:1 AFR)
