1/4 time
Started by sschung, 11:08:29 PM / 12-Jun-04
sschung
1st time at the track. times were *all* over the place.
best run:
time : 15.31
trap: 91.85 mph
60\': 2.225
reaction time: laughable. i don\'t think i had a single rt below 1 sec
tempature was about 20C
specs:
ca18et
cone filter
t25
14 psi spike to 10psi steady
small fmic
2 1/2 turbo back exhaust (cat & stock 2 1/2 muffler)
stock tb
gasket match ported intake
colt cam
street tires
removed spare and jack but no other weight reduction (1/2 tank of gas)
i\'ve got a cardomain site!
http://members.cardomain.com/sschung
YellowPreludeR
very nice. arent tracks fun !
--Yellow--
Current Car : 1984 BMW 533i Turbo /w custom M30B34
[Oo=00=oO]
Old ride : 1985 Nissan 200sx Turbo /w custom CA20ET
  (O=O/ S-12 O=O)
Johnnyfive
yaaaaa!  :mrgreen:
2004 Dodge SRT-4:
Stage 1
K&N drop-in
mopar BOV
Quicktime performance cutout downpipe
psi-fi motormounts
$20 catch can
1986 200SX turbo* FO SALE!!!
For sale as parts
westside27375
Good time sschung...Are you still using the stock clutch? Is the car still having those running issues? Did you sping the tires lots or just a bit?
Travis Hatt
85 Nissan 200sx w/CA18ET: SOLD
Mr.200
VHT trackbite + new sticky tires (an LSD would help too)
That\'ll solve your 60 foot time, but will require probably a 4,000 rpm launch to not bog.
But I wouldn\'t dump the clutch on anything that didn\'t have a whole lot of drag slicks behind it. Feather the clutch to get traction.
As for getting your r/t down, launch when the last light is still lit up. This is the biggest hurdle to get over as a drag racer. It will seem like way too early,
If you\'re still too slow r/t wise, try and launch when the second last light is still lit.
Basically try a couple non-variable ways. You\'ll either red light or be slow or be close. Then you can build yourself your own \"I launch when\" for consitency.
For your first time out, running a 15.3 in a car that still has bugs ... damn.
First time I hit the track I ran a 16.6. Heh, eventually without changing anything other than technique I shaved about 4 seconds off that ;)
1987 200sx CA18ETi - The Toad
1972 Dodge Charger 413ci/6.6L - The Bully
Matt
http://www.angelfire.com/freak/brutesquad/index.html
Euroboy
you run a 12.6 on the 200 or the charger?
Well i got a \'87 200sx
Mr.200
heh ... neither.
My first car, a 63 Pontiac Acadian with a 383 stroker went into the high 11s.
Then they kicked me off the track ... bastards.
Slow reaction time, that made me mad, so I over gassed, spun ... man, embarassing.
Charger\'s only barely into the 13s on streets. The 200 ... I shudder to think ... in its present state, maybe high 18s?
Matt
Alex Frost
Don\'t worry, we will have your 200 running properly soon enough...8) (praying to god that it will be something cheap that broke) 8)
The Nissan S12 Silvia...built while Nissan was still smokin' the green stuff
Cars...
2004 Nissan Sentra SE-R Spec V
1988 Toyota Supra Turbo->->NOT SO Turbo
1987 S12 hatch...KAZU is BACK!!! and she still runs!!!
1986 S12 hatch...GONE!
1980 Toyota Celica "Sunchaser" w/ 20R Sold
Team Frost; there's nothing faster than cats on grass!
