Shame that most of my posts have been lost, as the spec was detailed there.
Basically the spec is (if i can remember):
DET block
DET crank & flywheel
DET rods
JE forged pistons 7.8:1
268deg cam 1mm extra lift
Adjustable vernier pulley
Cosworth T3 turbo
Adapted DET front facing inlet manifold
Volvo intercooler & rad
S13 clutch
FSE adjustable fuel regulator
Bosch 040 fuel pump
17psi boost
I\'m going to convert to an aftermarket ecu and then run 20psi of boost.
